Go Back   PinoyHandyMan Do-It-Yourself Community > In and Out of the House > Building Materials
  #11
Old 07-07-2007, 09:48 AM
boybi boybi is offline
Default Re: Hardiflex vs Marine plywood for ceilings
Di ba nagmumukhang papel ang Hardiflex kapag nabasa? Parang nagpi-peel off sya.
  #12
Old 07-07-2007, 02:19 PM
mikaztro mikaztro is offline
Send a message via Yahoo to mikaztro
Only if it has no proper paint primer and soaked in water more than 48 hours.
  #13
Old 07-07-2007, 04:31 PM
So kapag ginamit as ceiling ang Hardiflex and then nagkaroon ng tulo ang bubong, palit na rin ang ceiling?
  #14
Old 07-07-2007, 04:55 PM
Quote:
Not necessarily. It takes more than that para masira yung ceiling mo. If it is just tulo(water drip)..no problem at all...pwera nalang kung basang basa at babad na babad sa tubig(a big gaping whole in the roof while raining hard). A good paint can also provide good protection for any material.
  #15
Old 07-08-2007, 11:06 AM
Dami ko na kasing nakitang mga naka Hardiflex na ceiling na parang carton paper na ang itsura. And kung sa ceiling ginamit yung Hardiflex, di ba yung one side lang ang mapipinturahan? Yung nasa top portion hindi na napipinturahan?
  #16
Old 07-08-2007, 04:37 PM
Hardiflex are made out of fiber cement board material. Yes, most constructors usually don't paint the other side. But, it wouldn't hurt if you paint the other side as well with one coat just to protect it from moisture and water leak. Ficem boards are brittle thats why you often see carton like ceilings. Quality of work(construction/installation) has more to do with it than anything else.
  #17
Old 07-12-2007, 06:24 PM
gildred gildred is offline
Tatoski, tama si Nicolodeon tungkol sa spandrel. Iyan ang tamang definition sa Architectural and construction dictionary... Ewan ko nga ba kung bakit itong mga manufacturer's ay ginamit ang term na iyan sa kanilang product. Anyway, ang tinutukoy kong spandrel ay ceiling panels usually made of galvanized aluminum sheet . Ang mga suppliers nito ay DNsteel, Union Steel at alam ko karamihan ng mga manufacturers ng long span prepainted roofing materials ay meron nito. Here's another link to what I was referring to: http://steelintertech.com/eng/spandrel.htm
  #18
Old 07-16-2007, 11:08 AM
chieffy chieffy is offline
we used hardiflex sa ceiling namin...gumamit kami ng rivets sa pagkakabit nito sa aluminum frames...
wala naman problema except sa mga dugtungan/edges...solved this problem by buying wallpaper-like vinyl sheet...konting patching compund at liha lang ayos na...dun sa mga area na may rivets patching compound lang din itinapal namin...
  #19
Old 08-13-2007, 01:31 PM
tatoski tatoski is offline
Super Moderator
Apprentice
Thanks Gildred and Nicolodeon for the definition.
Tama si Chieffy there are people who use aluminum rivets to fasten hardiflex to thin gage steel furring. I've seen a lot of hamburger stores having ceilings constructed this way. They countersink the panel by pushing the drill letting the chuck act as countersink and then rivet away! Dami lang kinakabit. Spacing is quite nearer than using hardiflex nails or teks screws.
  #20
Old 08-14-2007, 05:53 PM
VtEC VtEC is offline
Member
Apprentice
Quote:
Originally Posted by mikey
Are Hardiflex really advisable for ceiling use? Many say that they fall off in time due to loose nail holes which enlarge when hardinail are overdriven. Please advise.
mas prefer kopadin ang plywood over the hardflex kasi mahirap maidentify kung may tulo bubong or wala since water repelant ang latter.just my 1cent
